enable mlag port reload-delay
Description
This command enables reload-delay on Multi-switch Link Aggregation Group (MLAG) ports.
Syntax Description
Default
MLAG reload-delay is disabled by default.
Usage Guidelines
There are cases where MLAG ports comes up quicker than ISC ports after a switch reboot causing traffic loss during this time gap. After using the configure mlag ports reload-delay command to configure a time delay for MLAG ports that provides enough time for ISC ports/neighborship of other Layer 3 protocols to come up, you have to issue this command to enable the timer.
The following example enables the MLAG reload-delay timer:
# enable mlag port reload-delay
This command was first available in ExtremeXOS 22.3.
Platform Availability
